I’m having issues getting the Peplink 380 to authenticate PPTP users using radius to a freeradius 2 server. Freeradius is sending an Access-Accept, however the peplink is disallowing the login.
Is there anything obvious in the attributes below that would explain why the peplink isn’t allowing the login?
Also, it would be nice if the peplink populated the NA-IP-Address correctly with the LAN IP address, I use that for filtering, If there are more than one peplink in the network that would then break.
<pre>
rad_recv: Access-Request packet from host 10.10.0.6 port 45810, id=155, length=158
Service-Type = Framed-User
Framed-Protocol = PPP
User-Name = "ed.groenendaal"
MS-CHAP-Challenge = 0x<removed>
MS-CHAP2-Response = 0x3<removed>
Calling-Station-Id = "123.208.207.98"
NAS-IP-Address = 127.0.0.1
NAS-Port = 1
Sending Access-Accept of id 155 to 10.10.0.6 port 45810
Service-Type = Login-User
MS-CHAP2-Success = 0x3<removed>
MS-MPPE-Recv-Key = 0xf6a22d548a72ab4766bc469016470968
MS-MPPE-Send-Key = 0x280bb6ffa83bd88ed1527a427b7547e2
MS-MPPE-Encryption-Policy = 0x00000001
MS-MPPE-Encryption-Types = 0x00000006
</pre>
Cheers,
Edward Groenendaal
ONEgroup Pty Ltd
