PPTP on Balance 20 - can't access LAN nor Internet
I am experiencing exactly the same problem. I have added the rules as described in previous threads in this post and I have enabled InterVlan routing but neither of these resolve the issue.
Please open a support ticket here for the team to further investigate.
Please make sure you include the following info in the support ticket for the team to further diagnose the reported issue:
  1. Enable remote assistant for the device:
    Peplink | Pepwave - Forum
  2. PPTP test account
    username
    password
Thank You
I am having this same issue. Using the rule it worked for a minute, then when I disconnected and reconnected it no longer works. The only thing I get is the Peplink config page. Inter-VLAN routing is enabled. It’s the same problem as others were having, with both local and remote networks using the 192.168.0.x subnet. The support ticket link in the above reply is invalid.
