I’ve been using Peplink’s PPTP connection for years. MY remote windows 10 PC has been connecting fine. All network activity goes through my Peplink Balance 310 at the office. When looking at my IPCONFIG settings I’d see the VPN connection showing the default gateway of the remote Peplink router and everything would be as if I am on my work network.
About a month ago, that changed. I can’t access network resources when connected. A trace to google does not go through the office network anymore. The VPN connection successfully completes on my laptop at home (client), but my IPCONFIG settings shows that the ip address of the VPN connection is still on the same subnet of my home LAN.
Windows settings on the connection are set to the default to use the VPN connection’s default gateway. Also the office Peplink no longer logs my connections. I’ve tried recreating the VPN on my laptop several times in case I changed something on the client side. I used to be able to create a basic VPN connection without any special settings.
The weird thing is that the connection authenticates the user. So I am actually connecting to the office, just don;t have access to network resources…
Any thoughts on what to try?
