Connected to 20 years plus Firelite panel. Replacing Comcast VoIP with Pots adapter VoLTE.
Using ‘connect Id’ protocol. Connection made for 12-18 seconds. Fails handshake. Disconnects.
Limited access to panel provider does not understand VoLTE different from VoIP.
Any simple test I can use to test connection?
Hi Michael,
Could you please create a ticket and then write a ticket number via PM to me. We will follow up from there ![]()
G.
I already had a ticket open for a month and Peplink could not resolve. I was tired of waiting days for responses and closed ticket. I was hoping someone in community might have a solution.
Did you find a fix for firelite?
Did not resolve Firelite over POTS adapter. Set up adapter for correct protocol on panel. Could see connection for 12-18 seconds. Did not have access to panel, think hand shake was failing . Fire tech had limited training. None on Ademco/Honeywell Firelite.
