I’m interested in purchasing the Pepwave Surf Soho MK3 and have a few clarifying questions before I go ahead. My setup will be a Primary WAN connected to Starlink and a Secondary WAN using either a Mifi M2100 5g/4g or Iphone hotspot connected by Wifi as WAN. Starlink is fast for our rural area (~100mbps down / ~20 mbps up) but suffers intermittent dropouts as it is still in beta. My main goals are to (i) Provide an automatic failover solution and (ii) Ensure uninterrupted Zoom and Teams calls for a work/school from home setup.
So far I’ve been using Speedify to bond the connections. This has worked well so far. The limitation is that Speedify cannot be installed on my kids’ school devices. My questions are:
- Can SpeedFusion cloud with the Surf Soho Mk3 provide both channel bonding and hot failover or only hot failover? I wasn’t sure as the device seems to support only failover and not load balancing.
- I’d like to restrict SpeedFusion cloud (bonding/hot failover) to Zooms/Teams - is this possible? i.e. can I bypass SpeedFusion cloud for certain applications?
- Can I restrict SpeedFusion cloud to be used by particular clients? e.g. not for house guests. It looks like a separate SSID can be created in the 8.1 firmware release notes - is this compatible with the Surf Soho?
Thanks in advance!
