vsense
December 26, 2023, 9:12am
1
Hello I trying to do simple setup(see on attached scheme) with speedfusion VPN, but unfortunately I can’t access to the camera…
I established speedfusion connection, but don’t have ping between devices, why?
I can’t access to my IP camera
Please explain what I need to do to access to my camera?
Thank you in advance!
The ip range on both sides look to be in the same /24
Are you doing L2 speedfusion vpn, or doing a 1-1 vnat?
vsense
December 28, 2023, 9:59am
3
L2 speedfusion vpn and yes did different range because otherwise speedfusion vpn can’t be established…
Hi I am doing port forwading via L3 Pepvpn. the vpn established but we can not ping remote from aggregator. is there any setup document for port forwading via pepvpn ?
