Port Forwarding Question
Looking at getting a Pepwave Surf Soho for a remote office. I will need to forward ports for their video conference unit and white list the external IP addresses that can connect to it. (i.e. forward port 1720 but only allow specific external IP Addresses) From what I can see in the manual, I should be able to do this with a combination of port forwarding and firewall rules.
I just want to confirm this before purchase.
You are correct on both points. Port forward the necessary ports to the inside IP and then under firewall rules you will just need to set the default inbound rule to deny all and then create a allow rule for the remote IP to have access in.
Thanks for the quick reply Jarid!!!
