I have a Peplink Balance 20. I have a Security DVR (port 18004) and Web Cam (port80) on my LAN. Port Forwarding is setup so the Ip’s & Ports get where they need to be. I use a DDNS service. All works fine on the WAN side looking IN towards those devices when entering my DDNS Address.
When on the LAN, I can not access those devices/ip’s when I enter the DDNS address. (NOR can I access when I enter my WAN IP) either way…
For example while accessing DVR from my cellphone app, all works fine on the cellular network end to DDNS address. But when on the LAN in Wifi mode and you try accessing via the same DDNS address, Nothing… Same issue with the PEPWAVE Utility App. Works fine when on the outside WAN, but when i’m connected on the LAN its not finding it.
Sure I can create another profile with the LAN IP and use while on the LAN but what a pain. I should only need 1 profile and 1 address per device. I hope that all makes sense. What am I missing???
