Hi all - I have a max br1 - lte e ipp 55 - it supports on LAN OUTPUT PoE mode B (dc and data on separate lines) - but my external device only supports mode A (dc and data on the same line) - is there a way to switch the output to mode A? - thks
Yes, we support PoE mode B. According to PoE specification, PSE can support either mode A or mode B. But PD need to support both.
