Please add Smartcheck to WAN/Wifi as WAN connections
Hi Pepwave development team,
This feature was requested back in 2015 and still nothing has been implemented…
Having the smartcheck algorithm on the WAN connections as well as cellular would be of great use for those (like myself) using the WAN port for additional LTE modems or satellite connections. Currently the best option is DNS lookup which doesn’t save you in the case of a latency spike or drop in link performance. I’m using both a Max Transit Duo and the newer Pro model.
