Ping Test on Idle Circuit
I just wanted to double check and ask if a static IP is ordered on the SIM card, will it be pingable in an idle state? For monitoring purposes we want to make sure the LTE circuit is live and the Peplink is reachable from an outside monitoring source.
If you have a static address the Peplink router should be pingable – if the carrier does not block it (e.g., with CG NAT.) Just make certain you have allowed it on your end …
I would also add that make sure as @rick-dc has pictured that the standby state is set to Remain connected.
