HI
I want to know if it possible to manage remotely the 8 sim of my pepxim with a HD4max outside of my network. For example I have a hd4 max in the network A, and PEPXIM in network A not linked directly. I want to use for example 2 sim of my pepxim to work with my hd4max. Thank you for our help
rgds
Hello @mamsbens,
Two questions for you:
- Are you using InControl2 for your devices
- What is the SKU/Model number of your HD4 (there are now several variations and hardware versions)
Depending on hardware versions, you might be able to use the FusionSIM (SIM Bank). If you supply more information, one of the Peplink team may be able to guide you. It may also be good to engage your local Peplink Partner on this.
Happy to Help,
Marcus
