Pepxim Blinking Green Status Light, not able to connect
Hi All,
I have a Pepxim which I am trying to configure to meet the new IP’s.
As the old IP wasn’t known, I have done the factory reset of 5-10 sec.
Status light just blinks green, no DHCP and no static IP can access the GUI.
Has anyone had this before?
Thank you and Happy Easter.
SIM injector does not have DHCP server. Blinking green status light indicates that it did not obtain IP address. Please try to connect it to DHCP server, after this you can reach its UI and set static IP if needed.
