I have the following setup.
[Host] → [Pepwave BR1 Pro with OpenVpn Client] → [ OpenVpn-AS in AWS Cloud ]
I am able to establish the connection between the host and Openvpn-As via TUN (layer 3).
My issue arises when running my app ( which is using multicast ). From the wire-shark on the host, I noticed that the info is send to destination 224.0.0.22 and 239.255.0.2 but I am not sure whether pepwave is able to handle multicast without using its pepVpn.
My question is whether if I establish the connection using Openvpn TAP, would I able to bridge the LAN to the Openvpn TAP?
Best Regards
