Pepwave surf soho mk3 different security settings google voice
I have purchased the pepwave surf soho mk3 got my home office. I presently use Comcast Xfinity internet using many devices Chromecast, internet chromebook with vpn and Google voice with no issues… My concern is will I be able to configure my new peplink to replace Comcast router and configure different security levels for each device because Google voice and Chromecast will only work using lowest security setting but I need higher security settings for others.
Don’t see anything obvious to be concerned about with that requirement. You’ll be able to configure VLANs on the SOHO to restrict communications between different types of devices on the local LAN and firewall rules to lock down traffic between VLANs/subnets and to and from the internet if you so desire.
Suggest you search on here for posts about VLAN configurations to see some examples and when the time comes and you have any questions there are loads of very security conscious forum users here who will be keen to assist you in your device & network configuration.
