For some reason or another each and every day the router stops broadcasting internet. I thought it may have been my usb modem but it works fine. Can anyone help me? I have to restart the modem in order for it to work again. Sometimes it happens 4 to 5 times a day. Sometimes it doesn’t happen for 3 or 4 days in a row.
I connect to the soho via USB cable to the att velocity with the velocity wifi off.
It is the same issue via lan cable during the time it fails. No internet.
I haven’t pinged the soho during the issue with above, however able to disconnect the att modem and connect to the att device and browse the net. I have to restart and reconnect the soho to work and sometimes it works the first reboot and sometimes it takes twice to work.
Mobile Internet card is good. I thought the same thing, so I was restarting both but come find out its just the soho, however I restart both anyways to ensure a good connection.
