Pepwave soho client usage data Not showing
When looking at STATUS , client list, the usage data shows all 0 for all clients
How do I turn this 9n?
It can’t be turned off. Are you sure the clients are using internet bandwidth?
I want to turn it ON
Yes some clients are…if I look at the daily report I see lots of use, but do not know which one
I know. My point was you can’t turn it OFF. So it is always ON. So something funky is happening.
Suggest you log a ticket for engineering to take a look.
