hello - kinda new here to pepwave/peplink, so excuse my dumb question…
I have a 3000 sq/ft home, it’s 2 stories, 30’ x 50’ on the ground floor and same on the second floor.
I currently run two Apple Airport extremes, both on opposite ends of the house. Coverage seems very good, as I am trying to get wifi out on both decks.
in looking at the Rugged AP, do you think I could reduce down to one Rugged, centrally located and still have about the same coverage?
the Airports work well, however, they seem to be liberal in dropping down to the 2.4GHz band and would like something like the rugged to keep them at the 5ghz band for noise immunity and speed.
or, should i plump down and go with two ruggeds?
the key is to also be able to stream airplay outside on the decks.
thanks.
