Connected the device with 4 Sim Cards 2 different carriers, it keeps on dropping connection. It will connect for a few seconds and then it drops. Device has no special configuration, is factory default. Please advice.
Common issue if the cellular WAN signals is poor. Do you check that ?
Beside that, how you power up the device ? Make sure sufficient power is given to the device.
