I’m using the Max BR1 for my home modem. I’d like to continue to use it as the modem, but add Google Wifi as my access point. Do I need to change the configuration on the Pepwave device to disable it as a wifi access point? If so, how would I do this? Thanks.
You don’t have to disable the WiFI AP on the BR1, but its probably a good idea so that you can control all wifi users using the Google WiFi app (it wouldn’t see those directly connected to the BR1).
To do that login to the device (locally to its web ui or via incontrol2) and hit the slider to diasable the AP on the main device dashboard (or device page in IC2).
On device:
On IC2:
Awesome. Thanks for the help!
Worked great. Thanks again.
