Does anyone know what is the best position (angle) the MAX BR1 Mini LTE antennas should be set to for the best reception? I am assuming they should not both be vertical, but at an angle.
Cheers
Steve
Cheers
Steve
In theory they should be tilted 45 degrees away from vertical in opposite directions from each other (so at 90 degrees). In practice doesn’t really seem to matter.
Thanks!
Steve
Hello Steve,
You may find useful the guide within the Peplink Partners area of the Forum, just search the forum for “Antenna Selection Guide”.
Happy to Help,
Marcus
