We have a pepwave Max mini which works fine for about 3-4 hours and then will just drop out. I cannot access the the webadmin page when it drops out and have to power off and back on to reboot it. It will then work fine for about 3-4 hours before dropping off again. I have disabled the health check but still drops out. Any suggestions?
I’m not the expert, but maybe upgrade the firmware? Usually when software fails it’s due to stack overflows or something eating up memory. Check your CPU usage on the main status page, should be idling near nothing when not being used.
Is it overheating? My MAX BR1 5G was overheating in the RV, fix was to add heat sinks top and bottom.
How could you tell yours was overheating? I have the same model and notice some performance issue in the afternoon, I’m wondering if it’s getting to .
The outside temp of the case is 115 degrees.
