Just bought and installed the mini hw3. Inserted the Sims and starlink via ethernet to the wan/Lan port .
On the dashboard I only see the cellular wan and not the starlink.
I thought this was plug and play.
Had an older pepwave max where both worked and I could switch their priorities.
Don’t know what I’m doing wrong.
it could be that you need to purchase a so called **Feature pack (**SKU MAX-BR1-MINI-LC-FP), which enables Ethernet WAN. By default, all ethernet ports are LAN.
Thanks mate, I’ll get the feature pack and see how it goes… Cheers
How do activate it after I have bought the licence
Hi Krish,
you can check this FAQ. It should answer your question
