Pepwave Max BR1 LAN won't connect to internet
I have a Peplink Max BR1 with firmware 6.3.5 build 2763. I have installed a Verizon Wireless SIM card. I can use the ping and traceroute tools to connect to the internet (I’m using google.com to test). I can connect to the device’s AP with multiple Wifi enabled devices and access the internet (both a cell phone and a laptop). When connecting the laptop to the LAN port (1 or 2) I can access the router admin page and change settings, upload firmware, etc, but I can’t connect to the internet. I can’t even ping google.com from a windows command line.
I’m sure there is some setting I’m missing somewhere, but I just don’t know what it is? Any help would be appreciated! Thanks!
I was finally able to get ahold of a differnet PC and for some reason it works. I guess this laptop doesn’t like the LAN connection for some reason but other devices seem to have no problem. Either way, I’m working now! Thanks!
