Pepwave max br1 juniper srx ipsec vpn
I was wondering if any one has had any luck creating an IPsec VPN between a Pepwave MAX Br1 LTE and a juniper SRX 240. the cellular account I have installed does not have a static internet facing IP address but the Juniper does. If anyone out there has accomplished this and still has some notes they can send my way that would be appreciated.
Chris
Hello cwhaland,
I haven’t personally setup IPSec between a Peplink and any Juniper products, but it should work from the Peplink side as long as the cellular provider isn’t blocking the ports used for IPSec. You’ll just need to make sure that the settings on both side match or the IPSec tunnel will not form or may break down and rebuild every X hours.
