Using this unit as Primary Router/AP for our network. Recently have a few uses needing to have access to the office network from remote locations (home/other). This is working, but appears that only 3 PPTP VPN connections are supported (ie. cant get a 4th user connected to VPN). Is this a limit in this functionality or is there something that can increase this.? Would be good to know this so we can determine if this is an issue going formward. I could not find and documented references on if this is a Hard Limit.
If another Pepwave unit might be better suited (and with a bit more speed/processing etc). That would be something to consider. We also use this unit (and a BR1) for Router-to-router VPN connecting our 2 facilities.
As an added question, I saw a user connected via PPTP (viewed active connections), but could not see a way to kick/close a connection that was clearly not in use (0 activity over 10 mins +),
Thanks in advance.
Rick
