Bru
April 27, 2017, 4:35pm
1
Hi to All,
onboard my boat I have this issue surfing on the net: ethernet connected 10Mb speed, wifi connected 1,4 Mb.
i think something works wrong
the drama is that i understund very little about routers and similar.
I’m using a data SIM in the slot A
Any idea where to begin from to fix this issue, please ?
Tanx
Bruno
May i know the device model that you are using ? Do you tested with the WIFI 5Ghz ?
2.4Ghz always easy to be interfere by the environment influence.
For more information, you can refer to the URL below:
Find and fix Wi-Fi problems, extend range and increase internet speed with our complete guide for your wireless network
Est. reading time: 30 minutes
Bru
April 27, 2017, 6:49pm
3
Hi, tanx for the answer
model is max br1 mini.
I don’t know if it is able to works at 5Ghz…
Tanx
Bruno
BR1 Mini supports 2.4GHz only. Please go through the troubleshooting guide that provided by Sit Loong. Alternatively, You may get help from your purchasing point.
