I need to create a rule that allows traffic inbound from a range of IP addresses on the same network segment. Is there anyway to accomplish this. I see “Any, Single or Network”. I would was surprised and disappointed not to find “Range” on the list.
Whats the range? You might be able to identify it with a fine tuned CIDR.
The firewall is getting a major revamp in the next firmware release with the ability to create aliases for groups of ports and I suspect ranges of IPs. Fingers crossed you’ll get the functionality you need soon.
How soon is soon? Can you create anything less than 0-255 range with CIDR notation?
