adelini
1
I would like to clarify some dubts regarding PepLink products and features.
PepWave, when routing dynamic protocol will be supported i mena OSPF v2?
Which are the models of PepWave devices support WiMAX? Which standard is supported, 4G WiMAX and/or wireless broadband standard IEE 802.16?
How can i plug a VSAT antenna to the PepWave? Do i need a VSAT Hub?
Best regards,
Adelio Moreria
Tim_S
2
OSPF is supported on the Peplink Balance 380 and above routers.
For WiMAX support you would need to use a USB modem, or a modem with an Ethernet hand off.
The VSAT antenna would plug in to the VSAT modem and then Ethernet to our product.
-Tim
adelini
3
This kind Pep products will not support OSPF ever? Is it in roadmap?
Best regards,
Adelio Moreira
Tim_S
4
For now, OSPF will only be supported on the Enterprise class of routers.
