Pepwave Br1 Mk2
I’m still learning. Am I missing something? The Dashboard tab. Under connection status. I only have Cellular 1 bar. How do I get a Celluar 2 bar? I have a Att sim in slot a, and a Verizon Sim in slot b… Thanks
You have a BR1. The ‘1’ is a reference to the number of modems inside. The single modem can only use a single SIM at a time.
So status will show the signal level of whichever SIM is currently in use.
