I have some BR1 MAX Slim With firmware 7.1.1 build 3102. I have tried to set up a Schedule to save Power on my sites with Solar and battery configuration. But the units do not go to sleep when they should. Have also tried to restart the unit after applying the time Schedule, but the unit won’t go to sleep.
Please give me some advice?
Hello r_veland,
The Schedule found under System > Schedule can be used for enabling/disabling WANs, VLANs, AP, etc. Peplink/Pepwave devices do not have support for putting the device to sleep using the schedule feature.
I hope this helps!
Zach
