I am currently using an old PePwave Device connector with an external antenna to extend a WiFi network. But its to weak and probably died due to a bad power supply.
I do have an AP Pro 500M available and wander if I can set this one up to repeat WiFi.
Thanks for your reply,
Rogier
@ScooterIT
Do you have the hand drawing diagram that can share here ? Need to know the actually requirement to confirm this. Just to confirm your device is AP Pro 300M ?
Pretty basic, the Pepwave PRO AP 500M connects to the existing WiFi network and rebroadcast it.
I am currently doin this with a PepWave Mesh Device connector but need to replace this. Preferably with this much stronger unit.
https://i.postimg.cc/P5VnGPys/New-Book-17.jpg
