I want to connect a Verizon Jetpack mobile hot spot via a Peplink To Go to my home Netgear router. I can’t seem to find the correct instructions how to do this. Any suggestions?
You would just connect the Jetpack to the SOTG via USB and then an Ethernet cable from the SOTG to your home router.
If you think you may need assistance getting it setup I would recommend buying from a certified partner.
Tim
