PEPLINK30 CONFIGURATION FOR A TWO WAN : WIMAX (2/2Mbps) + ADSL (2Mbps/300Kbps)
#1
Could you advise about peplink30 configuration to obtain best balance/agregation for a TWO WAN Scenario?
WAN 1:
WIMAX (2/2Mbps) Dynamic IP (Could be changed if is mandatory).
WAN 2:
ADSL (2Mbps/300Kbps) Dynamic IP
Thanks in advance.
#2
If you have an unlimited data plan for WIMAX, then I suggest defining a weighted balance outbound policy rule 50-50. Then, you might want to add other rules for traffic that uses specific ports. (e.g Persistence rule for TCP 443 to keep the HTTPS traffic on the same WAN) The configuration will basically depend on how each customer/administrator decides to use the internet links.
You can review the following article to better understand how the outbound policy rules work:
Note that you cannot achieve aggregation (2+2=4Mbps down) for a single session transfer. Here’s an article on load balancing vs aggregation: http://www.peplink.com/index.php?view=faq&id=111&path=19
