Just bought the Balance 380 - setting it up. Is there a procedure to connect the VPN tunneling to WatchGuard x1000 device at a remote location?
Thanks in advance.
Thanks in advance.
Hello Adrian,
Yes, there is a way to do that. Currently it’s not official. However, based on the customers’ request, we will show how to enable it.
Could you go to http://www.peplink.com/contact/support/ and create a ticket? We should be able to give you some instructions on how to enable it.
Best Regards,
Haruki
The Peplink Team
Thank you Haruki. I will create a ticket.
