hello
plz any confirmation if the Peplink support sub-interfces ??
hello
Yes in that a Peplink is a Layer 3 router that supports multiple VLANs on the LAN and can also route between VLANs.
So you can create Multiple LAN VLANs and assign separate IP addresses and subnets on the Peplink device for each VLAN.
Thanks very much for help
