Peplink MAX BR2 Pro - bonding Dual 5G/LTE
I’m inquiring about the MAX BR2 Pro and its capability to bond two wireless connections.
Specifically, if one modem is connected to a public network while the other is on a private network, will bonding be possible without any interruptions?
Thank you,
Tanguy
To clarify:
When both modems are connected, one is designated as the master connection. In the event of a failure of the master connection, can the second wireless connection seamlessly take over to ensure uninterrupted connectivity?
It could but you need to have a bonding gateway on the other side where the private network ends.
As Venn says, this is possible and desirable. Let’s us do seamless Failover from private to public networks and back again.
Actual network design will vary depending on the purpose of the private cellular network.
What is the use case?
