Peplink compatibility with Fortinet firewall
#1
Hi can anyone tell me if its possible to link up a peplink router to my company FORTINET firewall. This firewall is also responsible for VPN,SSL and VOIP routing. I assume that the PEPLINK will be installed before the firewall. How will PEPLINK affect my FORTINET firewall and its settings, considering that FORTINET also has Load Balacing mechanisms for my 2 WAN lines. Thx!!
#2
The Peplink Balance is fully compatible with your existing firewall, and most customers will deploy it in drop-in mode.
You are better off having the Peplink manage your WAN connections and letting the Fortinet handle that other stuff.
