Not sure where this goes but I cannot seem to find where to turn off pepvpn on my balance 305. Any help is great help.
You can not disable it but if you have no profiles configured then it can’t be used, and if you block TCP 32015 and UDP 4500 from public internet access then it can’t be accessed.
If Balance/MAX unit is placed behind a firewall, you would need to define the firewall rules and inbound port forwarding policy on firewall unit for the following port numbers in order to allow SpeedFusion traffic passing across the firewall.
SpeedFusion uses TCP port 32015 and UDP port 4500 for establishing the connections by default.
[image]
Note on Data Port:
This is the outgoing UDP port number for transporting VPN data.
By default, UDP port 4500 will be used. Port 32015 will be used if…
