Peplink Balance One BPL-ONE Firmware 7.1.0 Build 3433
I am attempting to connect my balance one router to azure through a site to site IPsecVPN and have not been able to get a vlaid connection. I have followed all the instructions on the Microsoft side for a Policy Based (Static Connection) which I see is what this router will only support.
I need hard instructions / Directions on what the configuration would be… All I am finding on the site is discussions with out reference to the actaul instructions on how this is to be configured…
Any help would be really appreciated. I am very new to this so dumbing it down would also be appreciated.
Virtual Network Gateway - Azure Gateway. This should be attached to your Azure vNet. The gateway itself also has a subnet so be sure to pick something that doesn’t conflict.
Virtual Network Gateway IP - Public IP attached to the virtual gateway. This is what the Balance one will connect to.
Local Network Gateway - This specifies the Public IP address of the Balance One. You also list the appropriate address spaces that are on your local network.
Connection - This links the local gateway with the virtual network gateway. It’s always where you established the PSK for the IPSec VPN tunnel.
On the Balance One
IKEv1
IP address of the Azure virtual gateway (public)
Select the networks you want to route
List your remote Azure networks. Should be your vNet subnets. Remember you can use vlan parring to route multiple networks within a single gateway
