Dear Sir/Madam,
Does the Peplink Balance 20 support TM Unifi (Malaysia)? Which mean replace the orange router supplied by TM? Does it support VLAN 500 for Unifi?
regards,
Dear Sir/Madam,
regards,
Yes we support PPPoE with Vlan ID.
Thanks you
hi there
can you attach tutorial with it?
Thank you admin for your reply
i am network engineer
i want to test it on my network first before deploy it on customer network
