I’m trying to setup port based VLAN on the balance 20. But the ports have no label on the Balance 20. I thought it would go from left to right (1-4), but it doesn’t seem to assign the correct subnet IP via DHCP Is there something I could be doing wrong.
The ports should be 1-4 from left to right when the ports are facing you. When you plug into port 1 and (for example) have that port set to only use VLAN 5, does it fail to give DHCP or does it give DHCP for a different VLAN than expected?
Any details you can give about what you are experiencing would be helpful.
Thank you for choosing Peplink!
Tanny
The Peplink/Pepwave Support Team
