Dear all,
I bought a pepelink balance 20 with 2 wan ports, then I activated the 3th wan port with license, then I plugged into 3 wan ports 3 lines of 100Mb each, can I have a total of 300 Mb ?
Best Regards,
Hicham
Dear all,
Best Regards,
Hicham
Hi. No not with the Balance 20 it only supports a max throughput of 150Mbps, You would need the Balance One with the extra WAN license to support that number of WANs & throughput.
See the specs here:
thank you so mutch Martin !
