Does any one else seeing that Peplink Balance 20 crush on 6.1.0 build 2517 sometimes it crashes after apply some configuration changes related to WAN (4G USB), firewall, and DHCP settings?
Sometimes its’ all good, but sometimes when I click apply device just becomes completely unresponsive. Nor via Web UI or SSH. Internet dies too.
Powercycle fixes it and it actually keeps new settings it crashed on applying.
Not something I have seen. We have a number of employee owned Balance 20/30s as well as numerous customer devices. Nobody has reported anything as of yet, I’ll let you know if we do see that somewhere.
Hi, I have the exact problem. I have 2 peplink 30 and 1 peplink 20 , Once in a while it happen, the router freeze and I can’t access to internet, I’m able to ping the router adress from LAN but not able to access Web Ui, but what is very strange is that several ip’s alarm on the network (temperature sensor, and intrusionmodule) are able to report status to the alarm company.
I don’t know why its taken so long to realize that these reboot problems weren’t just a one-off fluke and looked in the forums for any ideas or answers. I see that I’m not alone in noticing there is a pattern.
We have reproduced the issue in our lab. Currently, our engineering team is working hard to fix it. We will post more information if it becomes available.
I would like to post an update here about this issue. Currently, we are still working on a firmware in order to address this issue. The firmware would be released in probably 2 weeks.
I see it too occasionally when making config changes and saving. Also, SNMP reporting memory usage above 85% at all times since going to 6.1.0. Not a huge problem, I can wait for the FW update.
