Dears,
My pep link 710 work fine but there CPU hit the 100% most of the time so I do the upgrade from the ver4.8.2 to the ver5.1.13
When the reboot finish the firmware need to unlock but my warranty is expired how can I have this unlock key?
Dears,
You will need to get your device covered under warranty again to get the unlock key for version 5.x firmware. If your device is registered on our site you should find the link to purchase the TotalCare, otherwise you can also contact your reseller as well.
