i’m using 5.3.9 firmware and i’m using the wlan controller function. i’m currently using 2 AP.
sometimes the cable of one of the AP switch off (not an AP problem. external problem) and the manager report correctly that only one AP is online;
but:
the AP without cable still running (plugged with wireless on) so until i switch back on the cable all the user aren’t able to connect on the internet. is there a way to detect when there is no cable and turn off wireless settings so all wireless user can go to the another working AP??
I think I kinda see what we are trying to do here - if the AP no longer has uplink for any reason e.g. Ethernet cable unplugged accidentally, then the AP should stop broadcasting SSID, hence clients will be forced to connect to another AP broadcasting the same SSID with a functional uplink - is this what we are looking at?
if the AP no longer has uplink for any reason e.g. Ethernet cable unplugged accidentally, then the AP should stop broadcasting SSID, hence clients will be forced to connect to another AP broadcasting the same SSID with a functional uplink - is this what we are looking at? <
exactly!
thank you and sorry for my bad explanation…
Hi Lorenzo, a quick update on this feature request - we will implement uplink health check mechanism in the upcoming firmware for AP One. Please stay tuned for the release!
Great article, i just read one and you make simple conclusion and powerful to learn.I like the article’s name…at firs, it leads your mind to someting else. but very good article.
