I have Peplink 30 I tried connecting it to cisco switch 2950
but It didn’t connect
Plz help
Hello Newbie,
Thank you for your post. This may be due to the devices being on different networks? If the switch has been configured for a different network than the Balance 30 they will not be able to communicate with one-another. Other basic reasons that could cause no connectivity are a bad port or cabling, have you tried connecting the devices using different ports and/or cabling?
If you are unable to resolve the connectivity issue you can open a support ticket here.
Alternatively, you can call the distributor you purchased the Balance 30 from or our support line to speak with a member of our technical support staff.
Distributor contact information can be found here.
Thank you.
