Maybe I missed it, but is there a Configuration Guide or Quick Set UO Guide available for setting up simple networks behind the Peplink 30?
For example: If you have a Cable Modem and DSL Modem attached to the WAN ports:
How should the Modems and the Router be set up for For Load Balancing? What is the best way to configure the WAN and LAN setting on the Router? What needs to be changed on the modems?
How should the Modems and the Router be set up for Fail Over?
I looked at the specs for my router and noted that the LAN ports are listed as 10/100. Doing a web search, I see the ports listed as gigabit. Which is it?
