Peplink 20x eSIM HW Version Limitation
Is there a limitation to the hw version on the 20x for the Peplink eSIM? I’m finding that only HW3 is showing the profiles. Is there a workaround?
There is definitely limitations and here is a link with more details:
This is a hardware limitation so no workaround I can think of.
What is your use case for needing an eSIM?
There may be a work around to allow you to use an eSIM but depends on what you are trying to achieve
Hi Adam,
We are trying to convert 50 physical SIMs to a Peplink 250 GB eSIM pool for cost savings and easier management. Currently, it’s managed by a third party.
Where in the world are you so the right partner can assist you?
If you are in the US you can PM me one of the s/n I can check and see if it support esim and how we can help you.
Hi. We are located in the US. Massachusetts. We currently are using a partner, but was insterested in the pooled SIM option.
What hw version are your 20x ? Contact me [email protected] . Let’s see if we can set you up with a pooled plan.
