Peplink 1350 HA
Hello Dears,
Will you advise me with the following
I have two Peplink Balance 1350 which are configured as HA.
moreover there are 125 PepVpn profiles from 125 Peplink Balance 20 & some of them Peplink Balance 210 connected to the Master 1350 throughout
My Question is, Do i have to create a second Pepvpn profile from each Peplink Balance 20/210 to the Slave Peplink Balance 1350, or not?
If not, so i can clone this scenario to our DR, all what i have to do is to get a couple of Peplink 1350 and create the second profile from each peplink Balance to DR’s HA Peplink balance 1350
Second Question, if i want to active the third WAN connection for Peplink Balance 20/210 i have to purchase a licence? does this licence already include SpeedFusion and Bonding features or it’ll be separate one.
Finally, can i create a second In-Control.2 account and migrate my old configuration to it, if not, can i change the username for my current In-Control account.
Not necessary. Slave device will have the up to date config once failover happens between master and salve.
I would suggest getting help from local Peplink partner since this involves current network assessment and recommendation. They can provide better advice on this.
The license just for 3rd WAN activation. Anyway, Balance 210 comes with SpeedFusion Bonding by default. Please find here for more details.
Do you mean you want to change the Organization Administrator for the current Organization? If so, you may add the new username as Organization Administrator in current Organization. Then login with new username and remove the old username.
Thanks for quick & useful response
